Pool has been installed about 6 weeks now and I have a salt system. I was told the alkalinity would be high the first year while the plaster cures. I started adding muratic acid in gallon bottles as instructed by my builder. Recenly I've been taking my water to have it tested at the local pool supply and everything looks good except the Alkalinity and PH.
Saturday the Alkalinity tested at 160 ppm, Tuesday at 130 ppm and Thursday at 190 ppm. PH always shows 8.2
I was given "Easy Acid" by the Pool Supply and told to add two bags on Saturday, it looked high on Sunday so I added another bag, Tuesday I was told to add another and Thursday to add two more. That makes 6 bags of "Easy Acid" in 6 days! 1 bag is supposed to equal a gallon of Muratic Acid. Is this normal? Cyanuric Acid has tested in the range of 75 to 85 ppm which appears to be good. Water is very clear.
Can I expect to keep adding acid at this rate or is there something else I need to look at? Maybe I should just switch back to the bottled Muratic Acid from Home Depot.
