Richard,
Thanks, Thanks and Thanks again. your observations on the stabilizer level have been noted, 30 will be our target.
Our intention is to manage the clorine with a manual application of 3.5kg of dry 56% Diclor? granuals applied after sunset. (Should we need to top up during the day - maybe due to lots of bathers what is the best method? granuals into the Balance tank? Tablets?
we have been seperating Clorine and PH Down, should these be at different times or does it not matter?
My issue now is shoud i raise the CYA with stabilized clorine (over 90kg - 200lbs needed to achieve 30ppm CYA) or should I try and seek out Cyanuric Acid here in Turkey, we have spoken to 4 pool "experts" and none of them have ever used Cyanuric Acid when starting a pool from scratch!!!From my reading here on the forum I just don't understand that and so it does not instill confidence in me.
I will continue to run our PH at 7.0 until the TA is acceptable which will also bring the balance a little closer to acceptable.
We have 3 supposed pool "experts" coming tommorrow is there anything I need to know to get this pool right or do you think Ive covered the bases.
Again, I cant thank you enough for your detailed reply,
regards
Marc
(Turkey)
