Hello all,
first post here on what looks like a great forum for q&a.
I'm considering relocating the pump and filter on a 24ft. round above ground pool.
I'm no plumber or electrician but have done a little of each, and seems like it'd be a pretty straight forward deal.
quick reading tells me I may have a few issues to be concerned with before I begin, though.
1.) the length of the power cable run
2.) increasing the length of the suction and return lines.
my general plan is to replace the flex hose with PVC, burying most of it, adding maybe 15-20ft. total to the runs.
then, extending the power box by about another 20ft. or so.
it's probably already about 20ft. on a converted inside to outside box.
it's a 20A circuit, I believe, with minimal additional load -- lights, I think that are rarely powered.
the outside receptacle is a 20A GFCI, and I think the existing wire run is 12gauge in a buried Carlon conduit.
not sure of the pump specs, but will return with them later.
it's pretty loud right now and may require replacing anyway -- probably worn bearing; haven't had a chance to pull it apart yet.
how long do these things generally last? it get cold and rainy here in the winter, but rarely freezing. I didn't bring it in or cover it last year
anyone see any problems here?
also, is Carlon conduit just flexible pvc? can I use some wirenuts and their coupling with some regular PVC primer & glue?
I'm thinking I'd be better pulling a fresh cable run from the box on the back of the house.
thanks in advance.
Scott G.
Virginia Beach
