I'm hoping somebody here has some advice or insight on this problem.
The pool was installed in 2001. I purchased the house w/pool in 2003. I started having issues with Bromine levels last summer. I take my water in to a pool supply center for testing and Bromine is always 0.0. I have an offline PerformMax brominator setup.
Last summer when the problem started, I thought air might be getting into the system causing the required suction through the brominator to be low. I replaced all of the clamps and one of the venturi scoop fittings. I also took all the bromine out and made sure there wasn't a blockage at the bottom. This spring I replaced the brominator o-ring as well. The brominator is full.. but the tablets seem to be eroding very slowly. I've confirmed no air getting into the system. I also confirmed the venturi scoops are pointed in the correct directions to force water through the brominator.
So, now what?! I'm still getting 0.0 reading and am getting frustrated!
Thanks in advance for any advice you can give on this problem.
