We bought an older (but excellent cond) used Vita-Spa D15 (120 volt) and enjoyed it for two weeks. Suddenly yesterday a loud humming sound started. The sound would last a second, stop for a couple minutes and then repeat. It may have been the over-temp tripping and then resetting... but not really sure.
I unplugged the spa motor plug from the controller... noise gone... the motor or the controller is definitely the problem.
The spa motor does not run for the low speed circulation and I am not sure if it will work in the high speed mode for the jets (haven't tried yet). The motor/pump can be turned manually with normal drag. Took the back cover off the spa motor to check the capacitor, governor & switch, connections, etc. Everything seems ok but I really need a schematic to figure out if the controller or the motor is the problem.
Voltages going to motor from controller do not seem right... but it's hard to tell.
Any help would be greatly appreciated.
Many thanks, Robert
