I have an inground spa pump with a two speed motor. If I leave the pump on low speed, it is fine. If I turn off the pump and then turn it back on, it won't re-prime. I found that if I close the valve from the hot tub and open the strainer cover and fill it with water, then have someone start the pump and then open the valve, it works. Is this a seal problem?
