"then your pool water is from another planet"
>>hiding from the aliens<<
thank you, muss51 and chem geek, for the speedy reply. the only water added to the pool recently was about 2 inches of rainwater over the last 2 weeks. for about three weeks before i had the salt system installed i added absolutely no chemicals and the water was crystal clear. i also had a zeo sand filter installed at the same time and when i got that running it clouded up the water significantly. the water cleared up again for about 4 days until i added the cya, it has been cloudy since and i can see only about 3-4 feet down into the deep end. the liquid test kit was bought last august and stored in a cabinet inside my home. every time i have used it the water never really clouded when i swirled it and the little tube would overflow and i could still see the black dot. i went for a refill of the cya reacting agent stuff and they were out, so i bought the strips instead. i had heard they weren't very accurate, but all of the readings pretty much duplicated what the liquid test kit results were. as for the algae, let's not talk too much about the algae. it defies my will. i've tried to beat it over the head with just about every type of algae killer at leslie's pool supply. the mustard yellow algae killer, the black algae killer, the green algae killer, the regular algae killer, it just never completely goes away. the best i've been able to do with it is get it down to two bad spots; one about 3 inches in diameter and the other about 7 inches. the algae killers combined with super shock, and rigorous scrubbing with both the wire brush and the plastic brush will not make those two spots go away. maybe the algae is from another planet also? i currently have the 2 alien spots of algae plus a whole bunch of other colonies that are fighting to get a good foothold. i'm running the chlorine generator 8 hours a day and the filter 24/7. thanks for the bucket test idea. will try those tomorrow and let you guys know the result.......
