First, did you replace the check valve? Sometimes the ozone, over time will cause the check valve to stick and not allow the ozone into the water, and eventually burn up the ozonator. Next, besides the light, there are test strips that check for ozone. Ozone only has a 20 minute risdual in the tub water and I do not know how accurate they are. The best way I can tell is by the smell. When ozone is running, the bubbles have a very distinct smell (like the smell after a lightning strick that was close by) Its like a super fresh air smell, and if you get a deep whiff of it, it may effect your breathing (takes your breath away)
Yes, the new unit came with a new check valve, and new hose.
Will have to give it the sniff test tonight when I get home.
Thanks,
Bob
