hi all
many thanks for all the helpful tips i have already checked out
i am a newbie to the tub experience (as far as maintenance goes) and want to start off in the right direction. we have just bought a lakehouse that came with a spa, so its time to clean and re-fill it.
i am looking for a low maintenance system that could be left unattended for up to 3 weeks, 4 days to 1 week would be the norm.
have been considering the eco-one system, due to what sounds like is ease of use and not having to add stuff daily.
Each Use of Spa
1. Add 1 table spoon of Leisure Time Renew non chlorine shock
Weekly
1. Add 1 teaspoon of Chlorine per 250 gallons
2. Check pH (pH should be very stable with Eco One but you should still check)
Monthly
1. Remove and clean filters with high pressure hose. You should not need to soak your filters with eco one.
2. Clean top and bottom of cover with Eco One Spa Cover Conditioner and Restorer.
3. Add 2 caps of Eco One Filter Boost in spa filter compartment (or skimmer)
4. Add Eco One Spa Treatment (Light use spa treatment can be added only every other month.)
Every 4 Months
1. Drain spa
2. Go to step 3 on above instructions.
has anyone used this stuff, if so what did you think of it, is it really that easy?
any other thoughts or opinions to a system i could leave unattended for up to 3 weeks from time to time.
thanks
rob
