I plastered pools in Cali for 16 years and never seen one get plastered without blasting it. Now I have been in michigan for 10 years and havent seen one get sand blasted before re plastering them. I thought it was crazy but it works fine. The pools in the eastern states get much rougher than they do in the west. If your pool is rough acid washing it is fine. You must use straight acid and you must power wash the pool after, some guys neutralize it also. You must get all the hollow areas off and make sure there is no smooth areas. Never replaster without a bonding agent, NEVER. Do not let them make a home brew either. Their are 2 that is used by most, multi-coat, sgm bond coat. I would make sure that when the pool is bonded that YOU see what they are using. If its a normal size pool it only cost a couple hundred bucks for material and 1hour to roll it on. Some guys say its expensive because they are charging you way too much for it. I would not let any one plaster it that wont use bond kote of some sort. There is only 3 good reasons that a plaster job fails, No bond kote or bad bond kote application, didnt wet the pool prior to applying plaster, slow fill. I have plastered over 16,000 pools and would tell you if it was ok or not, ITS NOT!!! b.ross@att.net
Thanks a lot.
