I have a fair amount of experience with pools. I have always been told that spas are a completely different animal and I am now understanding why. I am taking responsibility for a 2500 gal commercial spa from new construction. I know what alkalinity does but am baffled by the contradictions I have read on this board vs. information in the NSPF CPO textbook about the alkanitiy. In the text it says Pools and Spas alkalintiy should be 100-120 (using Bromine). What I am reading on this board is most keep theirs around 80. What is the official alkanitiy level for a spa using bromine?
Here is just a few of my issues:
When I started to take care of this spa, the brominator was empty, so I went out and bought some bromine tablets.
I tested the CH and it read good at around 160
I tested the Alkanitiy and it was 60. So I dosed the spa (bicarb) according to the calculations. I gave it a few hours and came back and it tested around 110.
I then tested the pH and it was extremely high, so I put in about 16 ounces of acid and aerated the water. After a few hours, the pH tested 7.6 and the Alkalinity dropped to about 80. I thought I was Ok, but the next morning, the pH was again off the scale around 8. So again i put acid in and aerated. A few hours later, I was back at 7.6. Next morning it was above 8 again. And this is basically the way it has been for the last 4 days. The spa has not yet been used by anyone and I am due for inspection but frustrated at the pH's insistant rise. I understand that when you aerate water that the pH will rise but should it be this much maintenance?
This morning while walking with the one of the pool builder workers, when I mentioned the brominator on the spa, he said it was a chlorinator. I litterally had to show him that it was in fact a brominator. He said that when HE started the spa a few weeks ago, he put chlorine sticks in there! He also said it didnt matter and that they essentially do the same thing!
It then occured to me that maybe this is why I was having problems getting the chemicals to adjust. If he was using Chlorine sticks then it was leaving cynauric acid in the spa. Am I wrong in thinking this is really bad? Especially since I introduced bromine to the water? Could this be causing my pH problems? Should I dump the water and start over?
