Hello, I purchased a new Dimension 1 Venture Hot Tub aprox a month ago. Everything on the tub has worked perfectly so far with the exception of it's ability to maintain temperature with the cover off. With the thermostat set at 104 once the cover is removed it begins to start losing heat, and loses heat rapidly if running all of the jets. Usually within 1/2 to 1 hr of having the cover removed the temperature has dropped to 100. I let me dealer know the problem and they came and replaced the 3.0 KW heater with a 5.5 KW heater, but the tub is still experiencing the same problems. Just wondering if anyone out there has experienced the same problem and if anyone knows any possible solutions. I'm alittle concerned seeing as it still fairly warm outside and am alittle worried for when we start seeing temperatures below zero.
Thanks,
Jason
