New owner of pool with salt water chlorine generator. I recently used the generator to shock the pool (100% for 24 hours). In the future I will use bleach but thats another topic. Anyway, previous to shocking the the FC level was 2 -3 with the generator set at only 10%. I assumed this was because we have an automated cover and the pool is always covered when not in use.
The mystery is that 1 day after the shock (the generator is back to 10%) The FC level is zero on a dip strip (I know not very reliable) and about .6 on a drop test (cheap kind that turns yellow). I was expecting the FC level to be high because of the shock and not lower than it was before - and since I have a cover I really thought it would not dissipate so quickly.
Salt 3200 ppm
FC was 2 -3, now .6
CC ??? Not sure I was properly testing for this but thought it was basically zero
CYA 40 ppm
PH 7.6
Is is possible my CC was high and I burned it off with the shock and I was just not smart enough (or have good enough test) to tell me that it was a problem? The water seemed clear and there was not a strong chlorine smell. What else could be going on here?
Also, what/where is a good test kit for pool parameters?
Thanks
