Hi,
Costco sells many tubs from many different manufacturers. The Platinum II is a Hydro Spas tub sold through many distribution channels, including Costco.
The only reason I'm pointing this out is because I want to avoid the confusion where many lump together all tubs through Costco as the same, when in-fact, Costco sells tubs from many different manufacturers, including Keys Backyard, Hydro Spas, Infinity, and others.
This is normal. A flashing ECO and the water temp indicates that the water temperature is current.
I am not entirely sure with your specific model, but many spas equipped with a Balboa control pack with a Mode button operate like this:
Pressing the MODE button puts the spa into Program mode. While in Program mode, to switch modes (e.g. Economy, Standard, or Sleep) you have to press the COOL button to cycle through the modes and then hit the MODE button again to lock in your selection.
Let us know how you make out.
Regards,
Ken
Thanks Ken. I will try out your suggestion on changing the mode. The flashing of the current mode (i.e ECO) and the water temp is something we have not seen the first 4 months we had it. I appreciate your reply and I will let you know how it works out.
Thanks again....!!
