I help maintain an 18,000 gallon semi-private pool. This is at a membership only campground.
In the last 2 days I have had a problem with the water clouding so badly that I cannot see the drain in the bottom of the pool. My boss and I are really baffled about this. We use Taylor's K-2006 test kit. This is what happened and what the test results were:
Sat 8/11 8am
Free Chlorine 5.0
Combined Chlorine .4
pH 7.0
Alk 100
Calcium Hardness 230
CYA 36
TDS 620
Temp 84.2f
I added 23 oz soda ash to raise pH level. The pool looked great.
4pm
Free Chlorine 2.2
Combined Chlorine .2
pH 7.3
I did not test the others. We usually don't in the afternoon. Just the Chlorine and pH.
I added 1.1 lb soda ash to the pool to raise the pH. This caused the pool to become so cloudy that I could not see the bottom step of the pool in the shallow end. I then cleaned the 2 next to the pool filters and socks, cleaned the in-line filter basket and back flushed (we have a sand filter). I also added 3 oz Super Clarifier.
By 7:30 am the next morning the pool was clear and beautiful.
8/12 7:30am
Free Chlorine 4.8
pH 7.3
Alk 110
Calcium Hardness 240
TDS 632
Temp 83.9f
I added 23 oz soda ash to raise the pH (I have since found out that a pH of 7.3 is fine and I don't need to do that). The pool became cloudy again. There was no need to back-flush (the psi was 13).
Neither my boss or I know what is causing this. He thinks that it might be metals in the water, I'm wondering if the bottom drain might be clogged (the next-to-the-pool filter baskets are clean, as are the in-line basket filter and the sand filter, and the test results are within range).
Does anyone have any idea what is causing this, and/or how to prevent it?
Added: This also happened 3 weeks ago and we took the same steps that I took on 8/11. Also, my boss wants me to dump a gallon of muriatic acid into the pool tonight about 10pm.
Thank you.
Terri
Seaview, Washington
