Sam71 Posted October 14, 2014 Report Share Posted October 14, 2014 Hi all, First post in here.... Picked up a de-mountable style pool with a sand filter the other day and I am in the process of working out where it will go and draw up some plans etc. for council! The pool holds around 9500l (2500g), the pump/filter is meant to do 1000g per hour! I would like to run some pipes under ground instead of just using the short hoses that come with the pool! The pump would be around 8m from the pool! The main reason for this is to avoid running power underground to the pool! Just not sure if the pump would cope! Any ideas would be great.... Quote Link to comment Share on other sites More sharing options...
