Air In Pump Basket When Vacuum Is On
aGrandma
When my pump is running, if I move the valve all the way to one side it is drawing the pool water from the drains in the bottom of the pool, and the pump is quieter. If I move the valve so the pool vacuum is sweeping the pool bottom/walls, air gets into the basket and makes the pump a lot noisier. So, air is getting into the system when the vacuum is running. Any clues as to where that air is coming from? Would it be the valve itself?
