SteveUKmidlands Posted May 26, 2017 Report Share Posted May 26, 2017 I had a complete burn out on my Saphire spa and had the Davey/Spa-Quip Spa Power PCB - SP600/SP601 board replaced by a hot tub repair company. Ever since when running after a few seconds it stops quoting error 6. The repair company now wont respond to email or telephone so i'm stuck. This error should mean no water moving across the heater and hence shuts down the system. There clearly is water moving across the heater as all of the pumps bubble, blower, etc work. There are 3 sensors on the heater tube. A Klixon (thermostat type device), optical sensor and temperature sensor. When i disconnect the optical sensor i get error 8. When I disconnect the temperature sensor I get error 4 so i feel these must be OK. I have changed the Klixon...same result error 6! Now if i open circuit the Klixon the error goes away...but heater doesn't work! There has to be something simple and obvious but I can't find it help please! Steve Quote Link to comment Share on other sites More sharing options...
Boony Posted January 16, 2019 Report Share Posted January 16, 2019 Hi Steve. Hoping you can tell me what the solution was to this issue? I am experiencing exactly the same problem at the moment with an error 6 thanks Andy Quote Link to comment Share on other sites More sharing options...
Dodger Posted August 18, 2019 Report Share Posted August 18, 2019 On 5/26/2017 at 11:13 PM, SteveUKmidlands said: I had a complete burn out on my Saphire spa and had the Davey/Spa-Quip Spa Power PCB - SP600/SP601 board replaced by a hot tub repair company. Ever since when running after a few seconds it stops quoting error 6. The repair company now wont respond to email or telephone so i'm stuck. This error should mean no water moving across the heater and hence shuts down the system. There clearly is water moving across the heater as all of the pumps bubble, blower, etc work. There are 3 sensors on the heater tube. A Klixon (thermostat type device), optical sensor and temperature sensor. When i disconnect the optical sensor i get error 8. When I disconnect the temperature sensor I get error 4 so i feel these must be OK. I have changed the Klixon...same result error 6! Now if i open circuit the Klixon the error goes away...but heater doesn't work! There has to be something simple and obvious but I can't find it help please! Steve I have the same problem also with error 6 and also replaced circuit board and klixon. Did you find the solution? Any help would be appreciated Thanks. RH Quote Link to comment Share on other sites More sharing options...
Dodger Posted August 18, 2019 Report Share Posted August 18, 2019 Hi Andy, Did you find a solution to the error 6 fault? Thanks, Dodger. Quote Link to comment Share on other sites More sharing options...
JRP Posted January 11, 2021 Report Share Posted January 11, 2021 Bit late in the day but I had this error 2 years ago on two similar Sapphire Spa hot tubs (mine and my mums) which failed within 3 months of each other. I traced it to the impeller on the pump which had sheared on the vanes. Both hot tubs approx 7 years old at the time. Pump ran and everything looked normal then thermal cutout after 60 seconds as no water was actually being pumped through the heater. Fixed by buying a replacement head unit for the pump - approx £80 and I also changed the shaft seal for £6. I suspect the shaft seal failing allowed water to the "gubbins" and caused the impeller to seize/snap. Given the parts are all plastic and the 7 years of chemicals it's no surprise the impeller failed. Quote Link to comment Share on other sites More sharing options...
Stee Posted March 4, 2021 Report Share Posted March 4, 2021 I'm having the same problem. Where did you buy a new head from. Thanks stee Quote Link to comment Share on other sites More sharing options...
John1805 Posted July 15, 2021 Report Share Posted July 15, 2021 I have the same problem, had new heater, new pcb, and now new control pad. Still getting error 6. Pump starts and pumps for about 10 seconds then get error 6. Tried it with filters out, all jets open, no difference. Tried with the Klixon linked out, no difference. Tried with the Klixon open circuited, no difference. Have ‘hotwired’ the motor and heater and left running for 6 hours, pool got nice and hot, no circulation issues, motor not overheating. Quote Link to comment Share on other sites More sharing options...
