Showing results for tags 'hotspring'.
  1. Hello! On Thursday we have had our first startup of our new Envoy! So long everything is working fine and ok. Water reached 38 celsius = 100 F. Regarding the water guidlines we are not really sure about the right values. We are using the ACE system whereas the manual tells that the hardness should be 25-75 ppm, optimal 50 ppm. (Whithout ACE the main manual tells 100 to 150). Our water from the pipe has 300 ppm .... With the vanishing act we reduced to 75 ppm. - ok But some homepages and suppliers of hottubs recommend that the hardness of water should be minimum 200 or better between 250 and 400 to avoid corrosion of the pool parts. Can you explain me such statements and why there is a so huge difference? Am I destroying my hottub with such a low hardness? Tx for replys! Gernot
