Showing results for tags 'high limit reset'.
I was given and I have installed a Sunrise Spa from 1997 at the cottage for summer use only. It was in a garage until now. It has a Aqua Spa Pak model ASP-2000-6-yoDoes anyone have a manual? It seems to work quite well for its age, but I have trouble getting it to heat up sometimes. The heat dial (it does not have a LED temperature setting) seems to work but I get 98 F and other times 115 F. Does it heat up better with or without the jets on? What does the High limit reset do exactly? Sometimes when I press the High limit reset the heater light goes on but usually it does not. Is the heater on only when the red light is on? The previous owner had a few extra wires hooked on the main board that I am not sure what they did but want to restore. I will put a picture below and maybe reinstalling this may help. I am guessing a thermostat and on/off. I would also appreciate suggestions to fix heating temp and for where to get parts down the road. Thank you.
- 14 replies
- high limit reset
- sunrise spa
