Showing results for tags 'codes'.
I'm having an OHH code on my beachcomber hot tub I just replaced the smaller pump as the last one burned out. I filled from the filter housing, opened the bleed screw and drained all the air through there, everything seemed okay last night but when I checked it this morning it was still cold and there was a SNB code I pulled the sensor out (lots of water no air) and also unplugged it and sprayed with electrical contact cleaner Now instead of a SNB code I'm getting the OHH as soon as I turn on the breaker even if it has sat for a few minutes I also tried unplugging the b sensor and there was still an OHH code right away. Maybe needed more time to reset though ? Hoping it's not a circuit board. Don't really wanna keep throwing parts at it. Everything was working fine before the pump burnt out Any help appreciated ! Thanks!
Question: I installed the Balboa VS500Z pack from Spaguts.com in August 2017. This weekend the control panel started registering code HL (Difference between temperature sensors and a possible flow problem) and eventually LF (persistent Low flow problems) The heater shuts off and the temperature drops significantly. None of the issues Balboa suggest seem to be present. Water level is normal, pump seems primed, changed filter. I can keep resetting the pump and it will eventually heat back up, but I have to be in the tub hitting the pump button every 5 minutes or so to make that happen. Any other options, recommendations to get this cleared? Spaguts.com customer service sent Thank you for your inquiry. If your heating pump is Pump1 and you used the provided pump cord, then there should be four wires connected to the motor. When the spa needs to heat the water, it will activate the low speed circuit and supply 240V between the white and black wires. If the voltage is present and the motor is not running, then there is an issue with the motor. (not too clear on what they are suggesing I do here)
