Showing results for tags 'Temperature Problems...'.
Found 2 results
  1. Both air and water temp readings went to about 76 degrees without any change in displayed value despite changes in air and water temperature. I replaced both temp probes. Both air and water temp readings continue to show about 76 degrees. The air and water temps are about 90 degrees. Is there something in settings?
  2. I have a HS Prodigy that has given me excellent service over 12 years but I can no longer bring down the temperature below 104 deg. I have yet to catch the Hi Temp Limit light come on. So is there a repair for this short of replacing the whole board?? Forum NewBee
