1st this forum has always been a life saver , many thanks !!
I've got a solana TX 2005 with blinking lights. They've happened before and simply unplugging and plugging the unit fixed the issue.
Now it wont and the tub is cooling ( you can see heating mode is trying to come on, but runs 24/7 and worried this will burn out the motor eventually. ( bad timing since winter is here). Did a few tests , the heater lugs measure 120 against the binding wire ( against each other 0), so electrically seems ok. ( it's wired for 120V )
Can't Amp test the wires to the heating element as there is no access to get an app meter clamp on, so not sure if there is electrical flow through the element ( thought about a continuity test but not sure if that is indicative of a failed element) . Jumped the pressure switch as well ( removed connections bypassing the pressure switch and joined them with some romex) . Still blinking dots and not sure what else to try. Any advice would be awesome .
Thanks in advance !!
