SpaMon345 Posted May 17, 2006 Report Posted May 17, 2006 If I am not going to use my spa for weeks or maybe a month is it better to just drain it? Other than turning off the power and draining it, is there anything else I should do? Spa = Recreational Factory Warehouse - Leisure Bay - model Chesapeake Quote
Guzz Posted May 17, 2006 Report Posted May 17, 2006 If I am not going to use my spa for weeks or maybe a month is it better to just drain it? Other than turning off the power and draining it, is there anything else I should do? Spa = Recreational Factory Warehouse - Leisure Bay - model Chesapeake Get as much water out of the lines as possible, then you won't have stagnant water sitting in there, use a shop vac to clear them out. Clean the filters, and make sure the spa is covered to avoid solar distress. Have a nice vacation, Quote
grahamtasia Posted May 17, 2006 Report Posted May 17, 2006 If I am not going to use my spa for weeks or maybe a month is it better to just drain it? Other than turning off the power and draining it, is there anything else I should do? Spa = Recreational Factory Warehouse - Leisure Bay - model Chesapeake Why doees Recreational Factory Warehouse- Leisure Bay - model Chesapeake equal Spa? Quote
SpaMon345 Posted May 17, 2006 Author Report Posted May 17, 2006 Why doees Recreational Factory Warehouse- Leisure Bay - model Chesapeake equal Spa? Um, because that is my spa. Quote
grahamtasia Posted May 17, 2006 Report Posted May 17, 2006 Um, because that is my spa. The whole equation thing is bizzarre. Quote
SpaMon345 Posted May 17, 2006 Author Report Posted May 17, 2006 The whole equation thing is bizzarre. You must be a math major. Quote
spatech (the unreal one) Posted May 17, 2006 Report Posted May 17, 2006 The whole equation thing is bizzarre. Breath deeply Graham. Quote
grahamtasia Posted May 17, 2006 Report Posted May 17, 2006 You must be a math major. Actually, just a common sense major! Quote
spatech (the unreal one) Posted May 17, 2006 Report Posted May 17, 2006 Actually, just a common sense major! Still working on getting your degree? Quote
grahamtasia Posted May 17, 2006 Report Posted May 17, 2006 Still working on getting your degree? Yes. I probably will never get it! I will end up having enough to get through life though. Which is more than most!! Quote
Brulan1 Posted May 17, 2006 Report Posted May 17, 2006 a-mazing Put it in "SLEEP" mode if you have that option. Quote
