wilfried Posted March 30, 2006 Report Posted March 30, 2006 In about 2 months the water level of my spa lost about one inch (2cm) Is this normal ? Quote
windsurfdog Posted March 30, 2006 Report Posted March 30, 2006 In about 2 months the water level of my spa lost about one inch (2cm) Is this normal ? Sounds like you aren't using your spa much. One might expect to add an inch of water every 2 weeks or so. Quote
sharkman009 Posted March 30, 2006 Report Posted March 30, 2006 In about 2 months the water level of my spa lost about one inch (2cm) Is this normal ? You will lose some water due to evaporation. How much depends on how often you have the cover open. From what your describing one inch isnt much for two months. Even so it is a good idea to open the door to the equipment compartment once in a while and check for moisture. You can get unions or shaft seals that can leak and if you catch them early it can save you from making a major repair later on down the road. Good Luck Quote
wilfried Posted March 31, 2006 Author Report Posted March 31, 2006 So everybody who is owner of a spa needs to refill the water in the spa on a regular base ? Quote
windsurfdog Posted March 31, 2006 Report Posted March 31, 2006 So everybody who is owner of a spa needs to refill the water in the spa on a regular base ? Absolutely. Water evaporates when the cover is open, water is removed everytime anyone gets out of the spa, kids have a tendency to splash it out. Quote
Brulan1 Posted March 31, 2006 Report Posted March 31, 2006 Absolutely. Water evaporates when the cover is open, water is removed everytime anyone gets out of the spa, kids have a tendency to splash it out. condensation is a biatch Quote
Guzz Posted March 31, 2006 Report Posted March 31, 2006 condensation is a biatch An inch a week is normal, and it's no biatch (whatever that is) Quote
wilfried Posted March 31, 2006 Author Report Posted March 31, 2006 When the spa is not in use and the cover is not open, what happens then with te water level ? Quote
sharkman009 Posted March 31, 2006 Report Posted March 31, 2006 When the spa is not in use and the cover is not open, what happens then with te water level ? You shouldnt lose any water. Or very little. Quote
wilfried Posted April 2, 2006 Author Report Posted April 2, 2006 My dealer said that , even the cover is closed, youu'll can lose a lot of water by condensation of the underside of the cover. What is the opinion for this statement of everybody who use a spa ? Quote
windsurfdog Posted April 2, 2006 Report Posted April 2, 2006 My dealer said that , even the cover is closed, youu'll can lose a lot of water by condensation of the underside of the cover. What is the opinion for this statement of everybody who use a spa ? There seems to be some confusion in this thread regarding evaporation and condensation. If the cover is opened, then indeed a very small, not a "lot", of water that had condensed under the cover will run off. If the cover is open, evaporation of water will take place as the evaporative moisture is release to the atmosphere. Otherwise, condensation is not the issue....evaporation is. Back to your statement, wilfried, that even when the cover is CLOSED, water will be lost by condensation? Absolutely not. If your cover remains closed and you are losing a LOT of water, you better start looking for leaks. Quote
mjs Posted April 3, 2006 Report Posted April 3, 2006 I've two comments: FIRST: what you described doesn't seem abnormal. I use my spa 3-4 times a week, and lose an inch of water every week or two. If you don't use your spa, your water lose should be less, but it still may be noticable (say, an inch a month). I typically will add water when it drops about two inches, say every three weeks. SECOND: I doubt if you heard your dealer correctly, or maybe it was the way you posed the question. As you stated it above, I'd say your dealer didn't know what he was talking about or was BSing you for some reason. Since what you described here is normal, must assume there was a mis-communication. Here's why: the moisture that condenses on the bottom of the cover runs down/drips off back into the spa, hence NO WATER LOSS! There will be some water loss, of course, but it will be because you cover isn't 100% tight, and some humid air escapes, and perhaps a little condensation drips out at the seam, but this should be very little. Quote
Brulan1 Posted April 3, 2006 Report Posted April 3, 2006 There seems to be some confusion in this thread regarding evaporation and condensation. If the cover is opened, then indeed a very small, not a "lot", of water that had condensed under the cover will run off. If the cover is open, evaporation of water will take place as the evaporative moisture is release to the atmosphere. Otherwise, condensation is not the issue....evaporation is. Back to your statement, wilfried, that even when the cover is CLOSED, water will be lost by condensation? Absolutely not. If your cover remains closed and you are losing a LOT of water, you better start looking for leaks. If you open the cover often than the condensation will be lost more often hence more water missing. If the cover is on all the time than it sounds like a leak like windsurf said Quote
sharkman009 Posted April 3, 2006 Report Posted April 3, 2006 My dealer said that , even the cover is closed, youu'll can lose a lot of water by condensation of the underside of the cover. What is the opinion for this statement of everybody who use a spa ? Most spa covers are tapered so you can get condensation that runs across the bottom of the cover to the outside edge of the cover then drip down off the spa skirt but even if this happens it is usually not much of a loss of water. If you have a spa that the cover doesnt fit well you could lose quite a bit from evaporation. Quote
wilfried Posted April 5, 2006 Author Report Posted April 5, 2006 Thks for the answers. If anyone has anymore reactions, pls post it. Quote
poollady Posted April 6, 2006 Report Posted April 6, 2006 Thks for the answers. If anyone has anymore reactions, pls post it. Just make sure you have a well-made, well-fitted cover. Quote
