Bob Crane Posted June 28, 2007 Report Share Posted June 28, 2007 First time poster. I've got a 24' round inflatable ring pool. Someone gave me a frog and the mineral/choline pacs so I hooked it up. The directions say 1 is the lowest feed setting, 10 is practically wide open. After 1 week of being on '1' the cholrine is as high as the color will change on the test kit. It has used up 75% of the chlorine pack as well. I'm wondering if there is a way to tell if it is labeled backwards or something. Quote Link to comment Share on other sites More sharing options...
Strannik Posted June 29, 2007 Report Share Posted June 29, 2007 First time poster. I've got a 24' round inflatable ring pool. Someone gave me a frog and the mineral/choline pacs so I hooked it up. The directions say 1 is the lowest feed setting, 10 is practically wide open. After 1 week of being on '1' the cholrine is as high as the color will change on the test kit. It has used up 75% of the chlorine pack as well. I'm wondering if there is a way to tell if it is labeled backwards or something. there is a way to tell refill the pool with fresh water, change the settings to 10 and see how you go Quote Link to comment Share on other sites More sharing options...
tony Posted June 30, 2007 Report Share Posted June 30, 2007 First time poster. I've got a 24' round inflatable ring pool. Someone gave me a frog and the mineral/choline pacs so I hooked it up. The directions say 1 is the lowest feed setting, 10 is practically wide open. After 1 week of being on '1' the cholrine is as high as the color will change on the test kit. It has used up 75% of the chlorine pack as well. I'm wondering if there is a way to tell if it is labeled backwards or something. My pool came with a frog and two chlorine pacs. I had the same issue. You can either cut way down on your filtration or (as I did) install a bypass with a valve just in front of the frog to regulate the amount of water going through the frog itself without compromising the flow of the filtration system. In my 7000 gallon pool, one pac lasted a season supplimented with liquid chlorine. After the two pacs were used, I stopped using the system. Quote Link to comment Share on other sites More sharing options...
