Guest Joe Posted September 22, 2005 Report Share Posted September 22, 2005 I know someone who is going to try spa magic. He thinks you don't need to use a sanatizer along with it. I told this person that I think he is wrong and you still need a sanatizer. If I'm correct, does spa magic work with anything or not?? Thanks! Quote Link to comment Share on other sites More sharing options...
swimninit Posted November 25, 2005 Report Share Posted November 25, 2005 I know someone who is going to try spa magic. He thinks you don't need to use a sanatizer along with it. I told this person that I think he is wrong and you still need a sanatizer. If I'm correct, does spa magic work with anything or not?? Thanks! You are correct and Spa Magic is compatable with chlorine, bromine and ozonators. My dad has been using it for 7 years now. He adds a bottle of Spa Magic every 3 months and adds a little SeaKlear if the water gets cloudy. He shocks it with a spa chlorine (55% available chlorine) when necessary and runs the jets until the chlorine gases off. I've heard that it does not do well in 'party' tubs and hot tubs with mineral filters (ie ... Spa Frog). Well water with high iron %'s can leave a brown ring on the surface edge and high sulfur %'s can increase fowl (rotten egg ) orders. Also, the water temperature must be at 90+ degrees for the enzymes to be effective. You can read more about it at www.chemfreespas.com Quote Link to comment Share on other sites More sharing options...
