Pump, Solar Panels Help !
turbottt1
Hello to all. We would like to install solar panels up on our roof. Details as followed::: our 1 1/4 feed pipe will be place on the bottom of the pool. It will have to lift 5' vertical and then run aprox. 25' horizontal along the underside of the deck. Then it will run vertical again aprox. 10' up to the roof.[ 4/12 pitch] We plan on at least 6-2'x12' panels. My question is what size pump do you suggest? This will be a seperate system with no filter in line. Thanks for all info. steve
