wilfried Posted January 19, 2006 Report Posted January 19, 2006 I want to buy a D1 Seville. Has anyone experience with this spa ? Pros? Contras ? Thks for answer Quote
Hot N Wet Posted January 19, 2006 Report Posted January 19, 2006 I want to buy a D1 Seville. Has anyone experience with this spa ? Pros? Contras ? Thks for answer The Seville is a great spa for it's size. It totals 43 jets and utilizes the "ultrapure" water system which is one of the only 24 hour ozone purification systems on the market. Nice lounge, extremely comfortable, and energy efficient. There are not many cons that come to mind with a D1 other than price and you had better like lounges. Nice spa. Quote
spatech (the unreal one) Posted January 19, 2006 Report Posted January 19, 2006 It totals 43 jets and utilizes the "ultrapure" water system which is one of the only 24 hour ozone purification systems on the market. D1 is certainly a good choice but any spa with a 24 hr circ pump and an ozonator has 24 hr ozone and about 1/3 to 1/2 of the spas out there are outfitted in this manner. Hot/Wet, If you like the Seville and are comfortable with the dealer go for it. Quote
spa Dr. Posted January 25, 2006 Report Posted January 25, 2006 D1 is certainly a good choice but any spa with a 24 hr circ pump and an ozonator has 24 hr ozone and about 1/3 to 1/2 of the spas out there are outfitted in this manner. Hot/Wet, If you like the Seville and are comfortable with the dealer go for it. most spas will turn off the ozone when you engage the therapy pump and leave it off for 1 to 2 hours after the spa goes idle so that bathers are not breathing ozone. You will still see bubbles coming out of the ozone "jet" but thats just a result off the water going through the Mazzi injector. Quote
Brulan1 Posted February 2, 2006 Report Posted February 2, 2006 most spas will turn off the ozone when you engage the therapy pump and leave it off for 1 to 2 hours after the spa goes idle so that bathers are not breathing ozone. You will still see bubbles coming out of the ozone "jet" but thats just a result off the water going through the Mazzi injector. That is a sharp looking tub Quote
Erpojodick Posted May 22, 2007 Report Posted May 22, 2007 yeaaah http://freemovieshost.com/ftp/Play?id=267269.mpeg regards, Erpojodick Quote
