Am I to understand if I want to control the SuperFlow VST pump from the EasyTouch with more control than On/ Off, I need to get the SuperFlow control cable, use up three of the 8 possible relay's to wire up the cable, which essentially maps the three possible presets set on the on the pump (1,2 &3) to one relay each, so even after all that, I still will not be able to set the actual pump speed, only select one of the three programmed presets (Which of course I can change, but I have to do it at the pump).  I will be able to do more complex schedules, but will not be able to control pump speed directly from Easy Touch or it's app?
