I need to connect cut the clear ray cable (green connector) to hook it to the ozone connection (connecting 1) on the BP501 spa pack. I’m not sure how to wire the 3 wires to the 4 sprinted amp connectors, any help will be appreciated. Thanks!
You will either need to find an adapter to go from a J and J mini to an amp style connection or cut that plug off and rewire it to an amp pin style connector.
I'm guessing the pack was swapped out at come point?
If it has a circ pump it has to be the same voltage as the clear ray and wired as such on the board.
Post photos of the circuit board and the schematic on the inside cover
You need something like this bit the female end has to match your existing male end as they are not all the same configuration: https://www.hottuboutpost.com/mini-jj-to-amp-cord-adapter-cable-bdlamptojj/
