Renegade Posted July 27, 2024 Report Posted July 27, 2024 Hi i have a Lay Z spa which is 4 years old and has been working well up until a few days ago. It says ”Error02”. Troubleshooting done: -Replaced the filter with a brand new one -Waterlevel is OK -Reset the pump and restarted serveral times -disconnected the pump and hosed in water for five minutes into the two pipes that pump in and out water from the pump and into the pool - Checked the inlets Into the pool from the pump and they dont look clogged Any idea what steps I should take now? Two things seem a bit weird. When I disconected the pump from the pool water kept flowing right out from the pipe that is for the Airbubbles. i had to put a cap on the airpipe from the pool so that the water would stop. Anyone else had that? See attached video, I thought only air is supposed to go in there the second thing is the black plastic in the filter house is a bit loose please se pic IMG_7098.mov Quote
