jb32172 Posted June 1, 2023 Report Share Posted June 1, 2023 Hi I've been struggling with fixing a leak. Seems to be coming up from floor underneath control box in equipment compartment were it bolts to floor? Maybe cracked drain line underneath? I will try to upload video if anyone can help. Thank you in advance Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 6, 2023 Report Share Posted June 6, 2023 Drain lines can be a problem on a HS, but the fact is the foam used is closed cell and tracks water and there's a sheet of plastic on the bottom that causes it to mostly hold water. If it leaks faster than it can seep out under the edge, it comes out right there as it fills the bottom. The leak could be across the tub. You're going to have to go digging, maybe block it up. Quote Link to comment Share on other sites More sharing options...
