Help with 2004 Hot Springs Vista leaking
Hi
I've been struggling with fixing a leak. Seems to be coming up from floor underneath control box in equipment compartment
were it bolts to floor? Maybe cracked drain line underneath?
I will try to upload video if anyone can help. Thank you in advance
Drain lines can be a problem on a HS, but the fact is the foam used is closed cell and tracks water and there's a sheet of plastic on the bottom that causes it to mostly hold water. If it leaks faster than it can seep out under the edge, it comes out right there as it fills the bottom. The leak could be across the tub. You're going to have to go digging, maybe block it up.
