Ben M Posted May 30, 2023 Report Share Posted May 30, 2023 Hi all! I have a Sundance Marin 880 installed in December 2022. We are leaving home for most of the summer starting this weekend, and I have just fully drained the tub since I'll have no way of maintaining it while I'm away. Question is: even though the tub is empty, there is (I am guessing) some residual water left in the lines. My concern is that the water will stagnate and then when we turn the tub back on in a few months, the jets will push out lots of nastiness. I used the quick drain valve on the front - is there anything I need to do to completely remove water from the lines? Thanks! Ben Quote Link to comment Share on other sites More sharing options...
cranbiz Posted May 31, 2023 Report Share Posted May 31, 2023 You will have stagnant water in the lines. Unless you blow out every jet and line, you can't avoid it. Quote Link to comment Share on other sites More sharing options...
Ben M Posted May 31, 2023 Author Report Share Posted May 31, 2023 12 minutes ago, cranbiz said: You will have stagnant water in the lines. Unless you blow out every jet and line, you can't avoid it. So my follow up question is - how do i blow out the lines? I thought I wasn't supposed to turn the blower on with the tub being empty. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted May 31, 2023 Report Share Posted May 31, 2023 External air source. You can use a shop vac that has a blower function or an air compressor. Quote Link to comment Share on other sites More sharing options...
nickrides Posted May 31, 2023 Report Share Posted May 31, 2023 I'd get a shopvac and set it up to suck and then put the suction hose on each jet under you feel it running dry Nick Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 31, 2023 Report Share Posted May 31, 2023 Spray all surfaces down with a mold inhibitor spray... https://www.homedepot.ca/product/concrobium-mold-control-spray-bottle-946-ml/1000150815?eid=PS_GOOGLE_D00 - E-Comm_GGL_Shopping_PLA_EN_All Products_All Products__PRODUCT_GROUP_pla-294971530742&gclid=Cj0KCQjw4NujBhC5ARIsAF4Iv6dgByALlxv3pA3BQRUE_1Kece428IhsUuulMwTlfbM9jMG_UET1mZUaApNIEALw_wcB&gclsrc=aw.ds Quote Link to comment Share on other sites More sharing options...
