Rob1613 Posted May 13 Report Share Posted May 13 Hello! My new Catalina swim was finally delivered and set up this week! But that's all I got - no instructions or guidance. The swim spa section has 3 "river jet" zones at the end that provide the swim resistance but they are not pushing out enough water volume to swim against and we just out-swim the tub. I changed every diverted to every possible combination with little improvement. Is there a valve or something I am just not seeing? All jets and pumps are on. Thanks for any help! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 13 Report Share Posted May 13 Most "swim spas" do not put out enough flow for a good paced swimmer. Leisurely breaststroke is about it if you're a lap swimmer. For a trainer you need an endless pool, which has you swimming behind a hydraulically driven boat propeller that moves the entire volume of the tub. Some swim spas have clip points for a swim harness on either side or the bottom, not sure on yours. Quote Link to comment Share on other sites More sharing options...
