blaster Posted December 7, 2005 Report Share Posted December 7, 2005 34 degrees, Phx., AZ this am. Freeze warning kicks the filter on. DEFAULT reads 3400ppm for the salt level, DIAGNOSTIC menu reads 0000ppm for the salt level. Is it supposed to read 0000? Quote Link to comment Share on other sites More sharing options...
Mark Posted December 7, 2005 Report Share Posted December 7, 2005 34 degrees, Phx., AZ this am. Freeze warning kicks the filter on. DEFAULT reads 3400ppm for the salt level, DIAGNOSTIC menu reads 0000ppm for the salt level. Is it supposed to read 0000? On my controller, when the freeze warning kicks on, it automatically shuts off the salt system so the reading is 0000. Instantaneous readings will only show when the cell is active. Even in normal operation, if you have it set at 50%, half the time, the reading will be 0000. Mark Quote Link to comment Share on other sites More sharing options...
blaster Posted December 7, 2005 Author Report Share Posted December 7, 2005 On my controller, when the freeze warning kicks on, it automatically shuts off the salt system so the reading is 0000. Instantaneous readings will only show when the cell is active. Even in normal operation, if you have it set at 50%, half the time, the reading will be 0000. Mark Thank you for your timely reply. That makes sense. Now I won't worry. thanks again Quote Link to comment Share on other sites More sharing options...
