Susanj Posted April 7, 2023 Report Share Posted April 7, 2023 When a heater in a hot tub goes out, my repair guy said it doesn’t sputter -it dies and it trips the circuit. I got up to our hot tub at our vacation rental last week and it was 68°. We thought a guest may have fiddled with it, and put it into economy or sleep mode but once we reset the breaker it was fine . Then this week , when guests showed up, it was cold again, and there had been nobody there in the meantime to fiddle with it. Again , resetting the breaker helped. I’m wondering if this is an indication that our heater is going . It’s seven years old . Our manual says when it’s in one of those economy modes, the heater will still kick on if the temperature gets below 80 , yet ours had been 68°. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 8, 2023 Report Share Posted April 8, 2023 2 hours ago, Susanj said: Again , resetting the breaker helped So it went back up to set temp after a breaker reset? 2 hours ago, Susanj said: at our vacation rental last week and it was 68° Was heat indicator light lit on the topside? Quote Link to comment Share on other sites More sharing options...
Susanj Posted April 8, 2023 Author Report Share Posted April 8, 2023 I’ve never noticed a heat indicator light, but yes, it went back up to the set temperature. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 8, 2023 Report Share Posted April 8, 2023 Well dirty filters is always the first thing the check. Slow the flow of water and hits hi limit shutting down heater to protect itself. Going deeper there could be a failing/sticking relay not going on/off as it should. If it happens again look for the heat indicator light being on but not heat. If it does happen again you will likely need to get in the pack with a multimeter and do some tests for power coming off the board. Quote Link to comment Share on other sites More sharing options...
Susanj Posted April 8, 2023 Author Report Share Posted April 8, 2023 Thank you. I don’t think it’s a dirty filter, because in between the two times it happened we changed out the filter. Quote Link to comment Share on other sites More sharing options...
Susanj Posted April 9, 2023 Author Report Share Posted April 9, 2023 I forgot to add that the first time it happened, we wondered if it was because the water was too low ( so didn’t activate the flow switch?). But I added water before it then happened again the 2nd time. Quote Link to comment Share on other sites More sharing options...
Cusser Posted April 10, 2023 Report Share Posted April 10, 2023 If the water level is too low, it could allow air to get into the plumbing system. And that air will need to get purged out to get a flow switch or pressure switch to activate the heater element. Quote Link to comment Share on other sites More sharing options...
