HotSprings Spa Owner Posted March 26, 2023 Report Share Posted March 26, 2023 Secondary drainage cap is leaking since taking off and putting back on. It’s threaded correctly and tightened. Thoughts on how to fix this? 70156692376__B2E193F0-B80F-424C-B329-769DBD7AC28F.MOV Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted March 27, 2023 Report Share Posted March 27, 2023 Like a garden hose there should be a rubber o-ring in the cap. Did it fall out? Or perhaps it needs replacement. Available at any hardware store. I always recommend not using the factory drain (weakest part on spas) and to use a Quick Drain. A Quick Drain can also be used as a vacuum in between draining the spa. https://www.poolstorecanada.ca/products/quick-drain Quote Link to comment Share on other sites More sharing options...
