Sal S0318 Posted March 20 Report Share Posted March 20 Hi I have a hard shell tub. It’s a Dream maker w/ a balboa rd 101. The 2 speed motor shuts off after a few minutes due overheating. I tested the voltage from the circuit board and I get 124ish from low speed and 116 ish from high. When pump stops on high voltage remains. Any thoughts?? Thanks in advance Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted March 20 Report Share Posted March 20 Sounds like a stuck pump relay on the board. Disconnect the pump from the board and test for power off the board. If you still get power and there is no pump 1 indicator LED lit on the topside then you have a stuck relay. They can be replaced fairly cheap. Quote Link to comment Share on other sites More sharing options...
