Farmspa Posted March 11, 2023 Report Share Posted March 11, 2023 Help! Quote Link to comment Share on other sites More sharing options...
cranbiz Posted March 13, 2023 Report Share Posted March 13, 2023 Gecko pack. It probably has an issue with the low voltage power supply. Depending on the age, it's likely that you may have some bad capacitors. You can tell they are bad as the tops tend to be domed out instead of flat and there might be a brown goo around the base. If you find this, replace the caps and see if it fixes it. Many times it does. If it's the power supply itself, good luck. I don't think anyone has found a source for just the power supply. 1 Quote Link to comment Share on other sites More sharing options...
