Dynasty Spa - Topside Controller not activating two speed pump
Hello! I recently had to replace the spa pack in my Dynasty Spa. Before replacing the spa pack, my pump 1 was a two speed pump, and pump 2 was a one speed pump. After installing the new spa pack, my spa is acting as if it’s programmed to be a single pump spa. Pump 1, when pressed only turns on and off, no high or low speed. Pump 2 will not turn on at all, nor does the top side controller seem to register that the button is being pressed.
ANY help would be appreciated!!! Thank you!!
