djhartm Posted April 18, 2007 Report Posted April 18, 2007 I have a Sundance Cameo that I am selling to my brother. the spa is 7'4" square and 39" high. When it was purchased, the folks from the dealer flipped the spa on its side to clear the gate, and used plywood and furniture dollies to move it. Here's the thing; my brother live 720 miles away. I have an SUV, and was going to rent a Uhaul open trailer and put the spa on its side. I am just worried that being on its side for that long (10+ hours) will stress and/or crack the shell. Uhaul doesn't rent flatbed trailers, so laying it flat seems out of the question. Any thoughts/suggestions? Thanks. Quote
Roger Posted April 18, 2007 Report Posted April 18, 2007 I have a Sundance Cameo that I am selling to my brother. the spa is 7'4" square and 39" high. When it was purchased, the folks from the dealer flipped the spa on its side to clear the gate, and used plywood and furniture dollies to move it. Here's the thing; my brother live 720 miles away. I have an SUV, and was going to rent a Uhaul open trailer and put the spa on its side. I am just worried that being on its side for that long (10+ hours) will stress and/or crack the shell. Uhaul doesn't rent flatbed trailers, so laying it flat seems out of the question. Any thoughts/suggestions? Thanks. For that distance I would lay it flat for sure. I never haul them on there side. Move into place yes, but transport over the road no way. Quote
waldorbigbill Posted April 19, 2007 Report Posted April 19, 2007 Sound like a pretty fasr trip to ride with it on its side. Maybe you could ask around and get a flat bed or why don't you try local junk yard maybe they rent one or advise you where you could rent one. Thanks Bill Quote
djhartm Posted April 19, 2007 Author Report Posted April 19, 2007 2ND rent a flat bed!! Where? I thought about using the plywood by setting it flat on the rails, and then securing the spa flat on top of that. Thanks for the advice. Ah Merde! Quote
Roger Posted April 19, 2007 Report Posted April 19, 2007 Where? I thought about using the plywood by setting it flat on the rails, and then securing the spa flat on top of that. Thanks for the advice. Ah Merde! Come and get mine. Duluth Minnesota. Quote
MaRiSpaTech Posted April 19, 2007 Report Posted April 19, 2007 Use 3-4 landscaping timbers to go across the trailer rails. This will provide support all the way across the bottom of the spa. Quote
104 Degrees Posted April 19, 2007 Report Posted April 19, 2007 Call a trucking company in your area. Quote
Trigger Posted April 19, 2007 Report Posted April 19, 2007 Is renting a truck instead of a trailer an option? A quick look at Uhauls website shows that some of thier trucks would accomodate the spa. Of course it would be more expsenive than a trailer,. and require a dedicated driver (as opposed to towing a trailer). It may also be more difficult to get the spa into the truck (higher up,), unless it has a lift gate.... - Just tossing Ideas out there. Quote
djhartm Posted April 19, 2007 Author Report Posted April 19, 2007 Use 3-4 landscaping timbers to go across the trailer rails. This will provide support all the way across the bottom of the spa. Good idea. As far as renting a truck, the milage (720 each way) would be prohibitively expensive. Quote
poollady Posted April 19, 2007 Report Posted April 19, 2007 Good idea. As far as renting a truck, the milage (720 each way) would be prohibitively expensive. 1440 mi. @ 69 cents per mile (UHauls lowest rate through the week) would be almost $1000. Definately cost prohibitive. But you might try to rent the truck one way that would include the days and the mileage. But then you'd have to find a way back home. [Hitchhike with a cute lady truckdriver??? ] Quote
waldorbigbill Posted April 29, 2007 Report Posted April 29, 2007 DJ was wondering what did you ever do? I was going to say if all else failed you could put tub by side of road attach a fake arm and have a cardboard sign reading need right to ??? Like a hitchhiker. LOL Seriously hope everthy thing worked out for you. Quote
JoeM Posted May 18, 2007 Report Posted May 18, 2007 I don’t know what part of the country you are in but here in Wisconsin, snowmobile trailers are readily available. I rented one form a guy in town (trailer sales) for $50 for the day. They are lightweight aluminum trailers with a payload of about 900 lbs. The one I got was 8' W x 10' L and fit my 92" x 92" spa perfectly. Just use some tie down ratchets and your set. I carried mine about 80 miles without any problems. Granted 750 miles is a lot more but the trailer should be able to handle it as long as you can. Just take it easy on the road and check it often. Quote
Mr Solo Posted May 18, 2007 Report Posted May 18, 2007 Tell your brother your are willing to knock off some money if he comes and picks it up. That way he can go through the hassle of getting a truck/trailer and, if something happens to it on the 720 mile journey, it's his tub and not yours. Quote
djhartm Posted May 23, 2007 Author Report Posted May 23, 2007 OK, so we are having a spa moving company come & load the spa flat on a Uhaul 5' x 9' trailer. I will get a 4' x 8' sheet of 3/4" plywood ripped to support the spa, and secure with ratcheting tie-downs. Quote
