Susanj Posted February 20 Report Share Posted February 20 And I thought it was just a marketing ploy to sell more of their test strips. Why should I use FROG @ease Test Strips with my FROG @ease system? A hot tub using FROG @ease does not test the same way as a hot tub using dichlor FROG @ease uses a unique chlorine, SmartChlor Technology, plus minerals to maintain a consistent low chlorine level and keep your hot tub water Cleaner, Clearer and Softer FROG @ease Test Strips were designed especially with an Out Indicator, a one-color match that designates when the SmartChlor Cartridge is empty. They also measure Total Alkalinity, pH, and Total Hardness levels for proper water balance When the FROG @ease Test Strip is lighter than the Out Indicator color block, located on the test strip bottle, it’s time to replace the SmartChlor Cartridge FROG Test Strips do not measure Free Chlorine Why? Since the Free Chlorine remains consistently at 0.5–1.0 ppm there is no need to test for it SmartChlor creates a reserve that converts to Free Chlorine when it senses the demand, it’s self-regulating. The reserve will start high and slowly deplete over the life of the cartridge as it converts to Free Chlorine when needed – no action required With standard chlorine, like dichlor, you must maintain a Free Chlorine level of 2.0 – 4.0 pm, much higher than FROG @ease, and you need to shock when the Total Chlorine level is higher than the Free Chlorine. With SmartChlor, Total Chlorine will always be higher than Free Chlorine until the Cartridge is empty. Total chlorine is represented by the SmartChlor reserve that is slowly used up over the life of the cartridge. Yes it's expensive but what I like is that with the chlorine they use, there is no CYA added so that's one less thing you have to watch and test for. We usually use non-chlorine shock. You can use Dichlor they say, but if you use it too often , then there's the CYA. Quote Link to comment Share on other sites More sharing options...
