BryanJ Posted February 8 Report Share Posted February 8 Hi, I have a 2014 Sundance 880 series Marin. I recently replaced the capacitor (same specs as original) on my circulation pump. It worked great for about a week but is now exhibiting the same symptoms again: the circ pump will hum but will not start pumping, display shows FLO error, water does not heat. Of note: I also replaced the flow switch when I put in the new capacitor, the pump shaft will turn manually with ease, filters are admittedly due for replacement (on order) but they not that bad, I have tried resetting the breaker. What could cause the capacitor to go bad again, or is it likely something else? Thanks, Bryan Quote Link to comment Share on other sites More sharing options...
