mpyner80 Posted January 28, 2023 Report Posted January 28, 2023 Ok...Here it goes. I've been reading alot of the great information in the water chemistry forum so far. I have specific questions about my situation. Brand new tub owner, filled up 5 days ago. 400 gallon tub. My current numbers (tested at the store lab): Free Chlorine - 1.5 PPM Recommended 2-4 ppm pH - 8.0 (although this is the max it will test they said) on a test strip it is off the scale (>9) Hardness - 110ppm Recommended 150-250ppm TA - 380ppm Recommended 100-120ppm TDS - 712ppm Recommended 0-1500ppm Few questions. Their program spit out a number of 785g of pH down. They also recommended 1/4 cup of muriatic acid every 20-30 minutes and retest, add more if necessary until TA is in range. The recommended ranges above are from the manual. Is this proper? Is muriatic acid ok to use? They never said how much I may need to add. Add calcium hardness increaser to increase CH (150g). This I can do pretty easily I think. I've added 1/4 cup of acid so far and am running all the jets. I guess I'll go with their recommendations unless I hear otherwise from the forum gods. Thanks for the info. Mike Quote
dashmer Posted January 30, 2023 Report Posted January 30, 2023 Suggest you read the sticky in this forum on lowering the TA. There are good detailed instructions on how to do it. It takes some time but you will get there. https://www.poolspaforum.com/forum/index.php?/topic/19149-lowering-total-alkalinity/ You didnt mention what type of chlorine you are using. A TA of 100 or more may be too high to keep you pH down in the correct range. If you are using the dichlor then bleach method, you will want to be down around 70 or maybe lower. Quote
