Doug ortega Posted January 21, 2023 Report Share Posted January 21, 2023 the temp reading for my pool and spa are currently both 234 degrees which is clearly not accurate. Pretty sure I need to replace the sensor. Since pool and spa are both reading the same, one would think it’s 1 sensor. But when it was working properly the temp reading was different when the spa heater was on. are there separate sensors for spa and pool? Air temp reading is accurate so assuming it is ok. Thx!!! Quote Link to comment Share on other sites More sharing options...
marielarmorell Posted February 10, 2023 Report Share Posted February 10, 2023 Yes, there are usually separate sensors for the spa and the pool. It is possible that the sensor for the spa is malfunctioning and needs to be replaced. You should also check to make sure that the spa heater is functioning properly and that the heating element is not stuck on, as this could lead to an inaccurate temperature reading. Quote Link to comment Share on other sites More sharing options...
