syeguy Posted November 29, 2022 Report Share Posted November 29, 2022 I have a artic spa model Malign 45. I recently found my spa display reading 222 and then r2 and then everything flashes and repeat. anybody have any ideas what is going on. Nothing works. I’ve tried turning off power, waiting a minute then turning back on. Same. thanks folks Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 29, 2022 Report Share Posted November 29, 2022 Post photos of the spa pack, circuit board and schematic on the inside cover if there is one. The board is stuck in a boot loop. Low level power supply could be the issue and you would need an electronics repair person to fix. Where are you located? Quote Link to comment Share on other sites More sharing options...
syeguy Posted December 10, 2022 Author Report Share Posted December 10, 2022 Sicamous British Columbia Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted December 10, 2022 Report Share Posted December 10, 2022 https://www.poolspaforum.com/forum/index.php?/topic/53524-gecko-inxe-spa-pack-stuck-in-boot-up-low-voltage-power-supply/&tab=comments#comment-208142 Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted December 10, 2022 Report Share Posted December 10, 2022 if you read sebast fix you will see he replaced the round capacitor. If the top of that capacitor is bulged outward it has likely failed. If you can find a local electronics repair shop they might be able to test and replace it. I have a guy here in Ontario. Short of that you are likely looking at complete replacement of a pack. Quote Link to comment Share on other sites More sharing options...
syeguy Posted December 11, 2022 Author Report Share Posted December 11, 2022 IMG_2373(1).MOV IMG_2373(1).MOV IMG_2373(1).MOV IMG_2373(1).MOV IMG_2373(1).MOV I had the power off yesterday, when I turned power back on the pumps started to work. It seems to be working now. Now I need to find out how to set topside control IMG_2373(1).MOV Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted December 11, 2022 Report Share Posted December 11, 2022 no videos Quote Link to comment Share on other sites More sharing options...
