HotPut Posted November 24, 2022 Report Share Posted November 24, 2022 Hi, I have a 500 gallon Clearwater Spa from 2009. Hooked up the spa for the season and one set of jets is not working. It has four zones of jets and two pumps, each pump running two sets of jets. Pump A runs jet zones 1 and 2. When I turn on zone 1 I can see the pump turn on and the jets work. I then turn off zone 1 and when I turn on zone 2 it makes a small noise but the pump doesn't turn on so it doesn't seem like an airlock (I would think the pump would spin for a bit with an airlock). I opened up the control panel and wiring. I checked all the fuses I could see and checked to make sure all connection were tight. Any ideas out there? Thanks so much! J Quote Link to comment Share on other sites More sharing options...
cranbiz Posted January 3, 2023 Report Share Posted January 3, 2023 Crack the union at the outlet of pump 2, let the water drain some and tighten it. This clears any airlock. See if you can manually spin the shaft of the pump. There should be a dust cap on the non wet end what you can remove and spin the shaft with a flat screwdriver. if it spins, the pump is not bound up. Then try spinning it when you engage the pump, it it starts, you probably have a bad start capacitor. Have you swapped the pump 1 and pump 2 connections on the board to see if pump 2 will run? If the pump runs, you may have a bad relay for the pump 2 control side. Quote Link to comment Share on other sites More sharing options...
