ddrueckh Posted November 15, 2022 Report Share Posted November 15, 2022 @waterbear I plan to use the 3 step Bromine sanitization method in an inflatable hot tub. I have a supply of Dichlor so plan to use that to shock instead of bleach for now. If using Dichlor, my research on this site has led me to believe I should have the following water parameters. TA 100-120 (higher than the recommended 50-70 when using bleach) pH 7.6 - 7.8 CH 130-150 Is this correct? In the below post are my starting water values. Thanks! Quote Link to comment Share on other sites More sharing options...
ddrueckh Posted November 15, 2022 Author Report Share Posted November 15, 2022 My tap water has the following parameters: TA 80 pH 7.0 CH 60 Quote Link to comment Share on other sites More sharing options...
waterbear Posted November 19, 2022 Report Share Posted November 19, 2022 On 11/15/2022 at 1:26 PM, ddrueckh said: TA 100-120 (higher than the recommended 50-70 when using bleach) This is for a chlorine tub or pool using dichlor or trichlor, particularity trichlor Quote Link to comment Share on other sites More sharing options...
ddrueckh Posted November 19, 2022 Author Report Share Posted November 19, 2022 Thank you for the reply. I will leave the Alk at 80 and see how it goes. I raised my CH and it went to 150. I’m currently at the following (all measured with a Taylor k-2106): TA 80 pH 7.2 CH 150 Br 5 I wonder if I will need to bump the pH up. If so, what do you recommend doing to keep it a little higher? Thanks. Quote Link to comment Share on other sites More sharing options...
waterbear Posted November 19, 2022 Report Share Posted November 19, 2022 2 minutes ago, ddrueckh said: I wonder if I will need to bump the pH up. If so, what do you recommend doing to keep it a little higher? pH tends to rise on it's own. If it drops then raise the TA to around 100 ppm. https://www.poolspaforum.com/forum/index.php?/topic/52522-some-truths-about-ph-and-ta/ Quote Link to comment Share on other sites More sharing options...
ddrueckh Posted November 19, 2022 Author Report Share Posted November 19, 2022 Thanks again for your help. I spent weeks trying to find good/complete info on hot tub chemistry. It wasn’t until I found this forum and your post on 3 part bromine that everything started to make sense! Quote Link to comment Share on other sites More sharing options...
ddrueckh Posted November 21, 2022 Author Report Share Posted November 21, 2022 @waterbear one more question. When shocking a bromine tub, do you add the amount the container says or just enough to get bromine to 10ppm (I'm using dichlor to shock)? The recommended amount really makes my bromine go very high (using a Toylor k-2106 to test) and takes 24-48 hours to come back down below 10. I would rather use less dichlor so I can use my spa sooner but wonder if it will not be enough to "shock" properly. Thank you for the information. Quote Link to comment Share on other sites More sharing options...
waterbear Posted December 6, 2022 Report Share Posted December 6, 2022 On 11/21/2022 at 12:17 PM, ddrueckh said: takes 24-48 hours to come back down below 10 not unusual. Are you leaving the tub uncovered and circulating after shocking? You want to bring the total bromine to above 10 ppm (around 15 ppm is good), and then wait until it's below 10 ppm to enter the tub. It will take a while. usually about a day. Quote Link to comment Share on other sites More sharing options...
